Chirping only while accelerating???
Old Jun 18, 2020 | 02:28 PM
DBLDisco's Avatar
Checked the front drive shaft it appears to be factory with snap rings and no visible grease buttons.
Old Jun 18, 2020 | 02:33 PM
DBLDisco's Avatar
It looks like this one
Old Jun 18, 2020 | 04:12 PM
boston4's Avatar
Try grabbing it to check for play in the u-joints. I suspect you'll hear some bad noises - should be nice and tight.
Old Jun 18, 2020 | 07:57 PM
merebel's Avatar
mine was tight with no play at all but the unjoint cap was cracked at the base. I had a bad vibration. Replaced with a lucky 8 one and everything was fine after that.
i didn’t see the bad cap until old shaft removed and then I could feel it and see the bad cap
Old Jun 19, 2020 | 05:27 PM
Extinct's Avatar
Agreed, the feel inspection is only valid with it out of the truck - 8 bolts.
Steven Gray
Range Rover L322 (3rd Gen)
Mar 9, 2022 11:29 AM
landroverdude
Mar 12, 2020 05:12 AM
desmd99
Jun 24, 2014 11:01 AM
KernowDiscovery
May 30, 2014 10:44 PM
pickps
May 14, 2007 12:42 PM
