city temp GOOD / hwy temp BAD
Old Jul 25, 2020 | 01:37 PM
clint70's Avatar
Default city temp GOOD / hwy temp BAD
So, I don't understand what is going on. The engine temp in the city is really good 193 solid all the time. WIth AC on it is 197 solid. BUT on the highway it climbs... 215/217. With the AC on FULL it is 221 (semi stable) but that was as high as I was comfortable letting it get. AC off... drops back to 212/215. I am in Ontario CA and it is a warm (30C / 90F) and highway is rolling hills.
WHAT is going on? Checked fan clutch, doesn't do more than 1.5 rotations by hand. Cleaned the Radiator fins... no noticeable difference. ?? I don't know what to do next or how to check other things. Engine is newly rebuilt (should not be an issue).
Looking for any advice / help.
Cheers!!
Old Jul 25, 2020 | 02:02 PM
Dave03S's Avatar
Sounds like proper temps for a stock thermostat... If that is what you think you have... There have been several cases of mislabeled 180 degree stats on the market. Also proper bleeding is key. Take a look inside the bleed screw hole when the engine is cold (first thing in the morning) and make sure there is no air right there... Coolant should be right up to the screw. If not top off right through that hole, then check again the next morning.
I can also say my system runs hotter on the highway when the air temp is above 85F but rarely over 200.
Old Jul 25, 2020 | 03:52 PM
Extinct's Avatar
You might want to look at my post in this thread: https://landroverforums.com/forum/di...mostats-90417/
Old Jul 25, 2020 | 06:37 PM
clint70's Avatar
Default Thanks
thank you for the read... great info. I liked the inline thermostat. But will look at getting a new 180 Tstat to see if the changes things.
my temps in town are pretty good I thought. But the 180 might fix all.
cheers
Old Jul 25, 2020 | 09:21 PM
CollieRover's Avatar
Maybe a blockage in the radiator/system? Making it less efficient at higher RPM's?
Richard Gallant's Avatar
If it helps I have been mapping my temps as I had a cooling issue
  • Black 78C thermostat from Bearmach
  • 2 hours temps at 14-16 C
  • Speeds ranging from 50 to 100 Kph (30 to 60) miles an hour
  • non stop mostly with 20 minutes of city traffic at both ends
  • heat off
  • low was 183.5 high was 195.6 averaged 188.6 to 190.4
Old Jul 25, 2020 | 10:50 PM
acg's Avatar
acg
I am currently running the default factory 192-degree thermostat (instead of the 180-degree thermostat). The reason is the shop which installed my Turner engine insisted on the use of the factory recommended 192-degree thermostat in order to cover warranty on the engine.
My Ultragauge shows temps around 195-degrees to 210-degrees. It rarely goes over 210-degrees with the 192-degree thermostat.
Hope this is useful reference.
Old Jul 26, 2020 | 07:31 AM
Shop doing what they had to do.
Old Jul 26, 2020 | 08:59 AM
Jwehking's Avatar
One time it took me several weeks to get all the air out. Another time I got it bled the first try. I found air causes temps to rise just as you described, hot on the highway.
Old Jul 26, 2020 | 02:27 PM
DiscoJax's Avatar
That doesn't sound right. I have an 180 deg stat and on a 90deg day I can see 200 while sitting in traffic and watch it drop to 180 when I get on the highway doing 80 mph. I can also see a similar temp drop on the air intake temps. Moving more air through certainly more than compensates for the extra btu's the motor is throwing off.
ROB99DISCOSD
Nov 15, 2017 01:20 AM
LRtoo
LR2
Jun 26, 2016 05:06 PM
blackcatphil
Jul 11, 2014 07:39 AM
aguison
Jun 14, 2014 12:17 PM
Savannah Buzz
May 12, 2011 09:08 AM
