CKP - Replace Before Failure
Old 02-23-2020 | 12:19 PM
cvhyatt's Avatar
Covered both my starter and CKP in remaining DEI radiant barrier. Will order a new sensor soon.
CKP wrap
Starter wrap
JUKE179r (02-23-2020)
Old 02-23-2020 | 01:26 PM
Extinct's Avatar
You can buy a spare, but I can almost guarantee it will never fail now. I had one going out - if I ran the truck, parked it 10 mins, came back it would not start. pour water on it - started. Cold started every time. I put a heatshield on it a year ago and have had not problems since.
The following 2 users liked this post by Extinct:
cvhyatt (02-23-2020), No Doubt (02-23-2020)
Old 02-23-2020 | 04:33 PM
Brandon318's Avatar
Where might one find this heat shield material?
Old 02-23-2020 | 05:55 PM
cvhyatt's Avatar
Here you go @Brandon318
Amazon Amazon
Old 02-23-2020 | 06:44 PM
No Doubt's Avatar
I really like the idea of heat-shielding the crank sensor, kudos.
Jury is still out on wrapping a starter in insulation, though. The starter motor itself can generate a lot of heat if engaged for any length of time, so insulating that internal heat might work against you.
However, if your Disco always starts up instantly, then it makes sense to insulate the starter from the cat's external heat.
Hence, jury is still out.
Old 02-23-2020 | 07:28 PM
cvhyatt's Avatar
A fair point. So far my starter is pretty quick on the job. I'll hit it with a temp gun after a cold start and see what it looks like after starting.
Old 02-23-2020 | 08:37 PM
Extinct's Avatar
You only need the heat shield between the starter and exhaust. Chevy starters (Disco is very similar) used to have issues when long tube headers were installed (back in the day before heat shields). Didn't your Disco have a heat shield on the starter? They come with one from the factory.
Old 02-23-2020 | 09:10 PM
cvhyatt's Avatar
No heat shield on the starter as far as I can tell. I will double check tomorrow.
Old 02-23-2020 | 09:57 PM
Brandon318's Avatar
Oh awesome! And it just self-adheres?
Old 02-24-2020 | 07:09 AM
cvhyatt's Avatar
They have products with an adhesive and some without. The link I sent you has a strong self adhesive on the back.
boston4
12-06-2019 09:51 AM
Robert Booth
08-20-2013 12:56 PM
Chris Donlan
01-02-2013 03:25 PM
RoverBimmerRX7
07-22-2011 09:16 PM
rczar
01-07-2009 07:07 PM
Quick Reply: CKP - Replace Before Failure
