Clicking noise coming from engine area
Old Jan 12, 2010 | 09:18 PM
kpl1228's Avatar
Default Clicking noise coming from engine area
2003 disco, 60K miles. Clicking noise......accelerates when RPM's get quicker but noise is not always there. Oil levels are good. Does it have to be a lifter?
Old Jan 12, 2010 | 09:39 PM
Could be a lifter, could be low oil pressure, could be the famous rocker arm tin "cup" coming apart.
First thing to do is have the oil pressure tested.
Old Jan 15, 2010 | 06:58 PM
kpl1228's Avatar
ok my fingers are crossed
Old Jan 18, 2010 | 03:48 PM
imarockstar's Avatar
Prob your oil pressure .. My oil pressure light comes on when the rpm's are under 1000. but the pressure is ok when driving. Dealer said my rober would not last 500 more miles and I needed a new engine. I told him to go **** himself, and 20,000 miles later its still going good. My recommendation ... Oil change every 3000 miles, THICK THICK oil and add slick 50 ..
Old Jan 18, 2010 | 04:30 PM
okdiscoguy's Avatar
a bad oil pump will not pump thick oil. To the OP, have you checked to see if you are in the bad oil pump VIN range?
RedAustinIX
Feb 1, 2022 11:58 PM
Disco28
Feb 27, 2013 10:49 PM
kpl1228
Feb 5, 2012 02:47 PM
apinky96
Mar 11, 2011 09:09 AM
domyo
Sep 25, 2008 12:19 PM
