Sponsored by: CARiD
Clicking noise coming from engine
Old Feb 28, 2011 | 10:07 PM
apinky96's Avatar
Default Clicking noise coming from engine
1998 Range Rover p38. Engine is smooth and runs fine but i have this constant clicking noise that i can hear when im at a stop. Any ideas? im thinking its a lifter but cant be so sure? thanks
Old Feb 28, 2011 | 10:48 PM
jackstraw's Avatar
Check the seal between the header and y-pipe. I thought it was a lifter too, until I was under there (trying to pinpoint the noise with the truck running) and felt the exhaust leak.
Old Feb 28, 2011 | 10:54 PM
apinky96's Avatar
Thanks, ill get up under there tomarrow and check it out. If thats the case how much is this a costly repair? (time and money)
Thanks again
Old Mar 4, 2011 | 10:47 PM
jackstraw's Avatar
Not sure what it would cost to replace headers and y pipe. All I did was tighten everything up. Unfortunately I am missing most of one stud on the header so I can't tighten the nut much without feeling like it will strip the stud. I have not fixed it totally yet. I just deal with the slight tic for now.
Old Mar 10, 2011 | 05:24 PM
distantecho's Avatar
6th Gear
What oil are you running? I had a ticking noise, changed the oil to 10w40 (it was running 5w30) and it went away.
Old Mar 11, 2011 | 09:09 AM
apinky96's Avatar
Yea im running 10w40, i think its a seal but have not had the time to get up under there and look. Thanks for the help
rezzrover
May 7, 2013 06:02 PM
kpl1228
Feb 5, 2012 02:47 PM
kpl1228
Jan 18, 2010 04:30 PM
domyo
Sep 25, 2008 12:19 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
