climate control
Old Mar 12, 2012 | 11:17 AM
LRDISCO75's Avatar
Default climate control
I have a 2004 Land Rover Discovery, my temperature control (climate control) won't turn on or off. the LCD screen is just blank, i pushed the power button but nothing happen. i have check the fuse under the hood, no luck!!? anybody suggestion what can it be?
thanks
Old Mar 12, 2012 | 12:34 PM
jafir's Avatar
Is the harness plugged into the back of it?
Old Mar 12, 2012 | 12:41 PM
Also have fuses under dash - please check 6, 7, 20, 31
Old Mar 12, 2012 | 02:52 PM
jafir's Avatar
If none of that works, it's a pretty pricey part new, but I've seen them go for as low as $35 used.
Old Mar 12, 2012 | 03:05 PM
If it is not a fuse and the harness is plugged in, try Paul Grant, his number is in my signature section, he will have a great price on a used guaranted unit.
Old Mar 13, 2012 | 07:16 AM
LRDISCO75's Avatar
Thanks all, will look at the fuse and the harness( what is he best way to get to check the harness ), also this doesnt have to do with grounding wired?
thanks again
Old Mar 13, 2012 | 07:33 AM
jafir's Avatar
I think it's easiest to remove the radio, reach down from above and release the clips on each side of the climate control unit and push it out. Rave shows doing it a little different I think.
Old Mar 13, 2012 | 10:17 AM
re: this doesnt have to do with grounding wired?
Go to the head of the class. If the ground wire from the HVAC control is loose, would do same thing. It is Pin 8 in the attached page - plug under dash. Rave electrical diagrams show you the color coded road map, electrical library shows you numbered connectors, like this one attached.
File Type: pdf
Green Blood
Dec 22, 2018 04:40 PM
FlyUgly
Jan 30, 2006 06:52 PM
jasonsLR
Sep 3, 2005 02:39 PM
M2K
Jul 21, 2005 02:56 PM
dbs600
Jul 11, 2005 08:44 PM
