Climate control buttons back lighting out
Old Feb 19, 2015 | 09:13 AM
completelymobile's Avatar
Default Climate control buttons back lighting out
Hi guys first I want to thank everyone who contributes to this forum as I would not be enjoying my old girl with out the valuable knowledge/experience gleaned from this forum.
I have been able to fix everything so far but have been stumped by this issue: when I turn on my headlights all of my dash lights work with the exception of the clock light and the 8 small climate control buttons including the drivers temp control (passenger side temp control lights up) … everything works as it should just no button back lighting at night with the lights on. Here is a picture to help show what is happening. I have checked all of the fuses inside and under the hood but everything looks good. Any tips or ideas would be greatly appreciated!
Attachment 24682
Old Feb 19, 2015 | 09:43 AM
drowssap's Avatar
did they ever work?
have you tried replacing any bulbs yet, they are 13 years old.
if you need bulbs i think AB sells a kit that gives you all the bulbs,
some are green some are white.
Old Feb 19, 2015 | 09:49 AM
dusty1's Avatar
bulbs?
How To Remove Climate Control Head On Discovery 2
Old Feb 19, 2015 | 10:39 AM
Motorhead1's Avatar
YouTube has videos on how to remove..You need to replace the bulbs, I had to do the exact same on my rig when I bought it. The bulbs are like 7 bucks piece, I freaked when I purchased them. The bulbs between the clock and the climate control unit differ i believe. It sucks not being able to see your heater controls at night driving down the road...
Old Feb 19, 2015 | 06:09 PM
sdhow's Avatar
Originally Posted by drowssap
did they ever work?
I believe the "green" ones just have little green bulb condoms over the white bulb.
Old Feb 19, 2015 | 06:18 PM
lordmorpheus's Avatar
Heh, "bulb condoms"... I guess I'm not the only one who uses that term after all!
Old Feb 20, 2015 | 06:51 AM
OffroadFrance's Avatar
You can also buy LED bulbs to replace all of the bulbs in the A/C head and they will probably outlast the truck. Removing the A/C head and replacing the bulbs is pretty easy to do but a bit fiddly.
Old Feb 20, 2015 | 08:10 AM
dusty1's Avatar
oh, those are for the bulbs! oops. my bad.
Old Feb 21, 2015 | 02:02 PM
Thanks everyone for the information ... got the bulbs replaced and all is good. FYI , I used a feeler gauge to slide into the side and release the clips on the side of the climate control and it worked great. Tried a small standard screw driver but it was a little to wide. Hope this helps!
Green Blood
Dec 22, 2018 04:40 PM
trp34
Nov 16, 2011 05:10 PM
SantaCruzRoverGirl
Jan 18, 2009 06:59 PM
M2K
Jul 21, 2005 02:56 PM
