Climate control issues
Old Jun 19, 2014 | 05:41 PM
sstevensonm's Avatar
Default Climate control issues
If I turn heat all the way up then it get very hot, I go down one notch and it blows cool. Now that its hot it randomly works really good or not at all. Is there a temp sensor that could be causing issues, or could the control panel be having issues.
thx
Shaun
Old Jun 20, 2014 | 07:32 AM
acamato's Avatar
Try running the manual AC diagnostics to see if you have any codes.
Instructions are here: https://landroverforums.com/forum/di...er-side-59299/
Old Jun 22, 2014 | 03:10 PM
Performed test no errors
Old Jun 22, 2014 | 03:23 PM
OffroadFrance's Avatar
The temperature that the A/C or CC operates to is relative to the cabin temperature existing. For instance, if the cabin temp is say 25C and you set the CC to 28C it will blow hot but if you set it to 24/23C or lower it will blow cold. It will depend on the reaction time of the in-duct sensor also and the recognition of the temp by the A/C controller head. All this is best done with an independent but accurate thermometer, preferably electronic digital type. Don't rely on the instruments in the dash as they are commercial average rubbish. For setting up I tend to use the recirc button and then the external air ingress. IMO it's best done in a relatively constant temperature say inside a garage as the exterior ambient temperature fluctuates too rapidly.
These may give you a better understanding.
https://www.google.fr/webhp?sourceid...ing%20circuits.
Green Blood
Dec 22, 2018 04:40 PM
cardinal77
Jan 18, 2012 02:39 AM
Desertdualsport
Oct 20, 2008 06:53 PM
jasonsLR
Sep 3, 2005 02:39 PM
dbs600
Jul 11, 2005 08:44 PM
