Clunk/clack when shifting from R to D or D to R
Old May 19, 2008 | 06:18 AM
GeorgeD's Avatar
6th Gear
Default Clunk/clack when shifting from R to D or D to R
I have a 2000 D2 that has 98K miles on it. When completely stopped and shifting between R and D (or D to R) there is an audible noise somewhere between a "clunk" and a "clack" that sounds like it's coming from either the transfer case or transmission. Both of the driveshafts appear solid. I checked them both when I lubed them a couple of months ago, and all U-joints appear to be good. I looked underneath while my wife cycled from R to D and back again a few times. It looks like both driveshafts spin a little until they take up the freeplay in the diffs/axles and that's when I hear the noise. When she put on the parking brake it did the same thing, only the noise was quieter, and of course the rear driveshaft didn't spin. This is something that has become consistent in the last few weeks or so.
Thanks in advance for your help.
Old May 19, 2008 | 07:31 AM
Default RE: Clunk/clack when shifting from R to D or D to R
It is normal, my '97 does the same thing. There is slack in the gears, both in the t-case and the diff's. You can help quiet this by having the fluid changed in both the diff's and t-case, have a 95w140 weight gear lube put in. If you use a full synthetic gear lube it will slow down the wear on the gears.
Tony Luna
Apr 28, 2015 12:31 AM
discoken
May 10, 2010 08:37 AM
tsuami1
Aug 11, 2009 01:40 PM
DiscoMike2003
Nov 13, 2008 04:57 PM
tsuami1
Jun 20, 2008 07:53 PM
