clunk from drivers side
RE: clunk from drivers side
I would first suspect the joints in your front driveshaft. Crawl underneath and see if there is ANY play between the parts of the shaft. You do not want to drive it with a bad shaft, it could explode and take out your tranny. Can you grease all three joints in your shaft?
Also, I noticed that if your cdl is engaged that there is a clunk when you first hit the gas. I don't drive on the street too much with it engaged because of this.
