clunk from drivers side
Old Dec 15, 2007 | 04:14 AM
darkside's Avatar
Default clunk from drivers side
on my 99 DI there is a clunk that just started on the drivers side front when accelerating, it only seems to do it when i first start driving and its cold, and ideas? it has 80k on it
Old Dec 15, 2007 | 08:21 AM
jkid's Avatar
Default RE: clunk from drivers side
I would first suspect the joints in your front driveshaft. Crawl underneath and see if there is ANY play between the parts of the shaft. You do not want to drive it with a bad shaft, it could explode and take out your tranny. Can you grease all three joints in your shaft?
Also, I noticed that if your cdl is engaged that there is a clunk when you first hit the gas. I don't drive on the street too much with it engaged because of this.
Old Dec 15, 2007 | 09:00 AM
I would check all the bushings, D1's do go thru them.
Make sure everything is tight, especially the shock, also make sure the shock bushings aren't gone same with the radius arm bushings.
cosmiccharlie
Aug 12, 2020 01:42 PM
Mavic19
Aug 27, 2014 02:42 PM
freshdew82
Nov 7, 2012 10:07 PM
99discoverysc
Jan 30, 2011 09:46 PM
DiscoMike2003
Nov 13, 2008 04:57 PM
