clunk in the trasfer case
Old May 25, 2023 | 06:54 PM
toofaroffroad's Avatar
Default clunk in the trasfer case
Hi, I've got a 2002 D2 with a hi/low shifting T-case in there. Was pulling out into a main st. a few months back and a big clunk happened under the truck. It drives and shifts fine but as you can see from the video it has a major clunk happening. I think it's the T- case and it clunks locked or open. Was wondering if anyone had any thoughts? In the video,looking at the front driveshaft into T-case you can see it jerk on each clunk.
Thanks for any help.
FYI, I've purchased a used T-case for a replacement.
File Type: mov
Old May 25, 2023 | 09:32 PM
hasullivan's Avatar
Not sure if it was an illusion in the video but it looked like the t-box side of the front driveshaft was thwopping.
Have you removed the front driveshaft (locked diff) and still heard that noise?
Edit:
Have you checked for play in the shaft/case at the connection?
Old May 26, 2023 | 08:43 AM
mollusc's Avatar
You say "hi/low shifting T-case" and then refer to "locked or open." All D2 transfer cases have high/low shifting. "Locked or open" usually refers to the second function of locking the case so that both outputs are equal. Many (most?) 2002 trucks didn't have that from the factory.
Could the clunking just be the front driveshaft failing?
Old May 26, 2023 | 10:06 AM
Richard Gallant's Avatar
@toofaroffroad That front drive shaft is dead - take it off before it let's go and you get to buy a new transmission. It is miracle it as lasted this long
Old May 26, 2023 | 10:17 AM
Hi Richard, hope your well. The front driveshaft is actually new. I installed it right before the RL trip last fall.
Old May 26, 2023 | 10:35 AM
@toofaroffroad I am well hope you are too, there is something very very wrong. I would still drop that drive shaft lock the CDL and see if the clunk is still there, it looked to me like the drive shaft was doing strange things.
Old May 27, 2023 | 02:59 PM
Well….I want to apologize for wasting everyone’s time.
I removed the driveshaft today and the truck seems fine when diff is locked.
I just didn’t even think about driveshaft since the one in there has maybe 3 months of drive time on it.
it even looks brand new.
Ill reach out to Lucky 8. Maybe they’ll warranty it.
thanks for all the replies.
Old May 27, 2023 | 05:03 PM
Harvlr's Avatar
Good news. A drive shaft is an easier fix.
Old May 27, 2023 | 08:49 PM
hasullivan's Avatar
I am happy to hear that it is something much less expensive that the transfer case.
JohnHZ3
Jun 25, 2021 03:35 AM
bosshogt
Nov 1, 2020 05:38 PM
Ian Mitchell
Nov 12, 2019 01:49 PM
ninjaff21
May 19, 2014 10:33 AM
csb
Jul 23, 2009 08:57 AM
