clunky shifting then flashing M + S...
Old Mar 4, 2024 | 07:15 AM
jamestfl's Avatar
Default clunky shifting then flashing M + S...
so I've been having more frequent clunky / rough shifting lately, especially uphill. at times, it will throw the flashing M+S and sometimes go into limp mode. also noticed that when it's really struggling uphill, the lights will dim, more strain=less lights. any ideas? TIA
edit- thanks for the replies, re: alternator. not much good at electrical. wasn't sure if it was battery / battery connects (just now cleaned them), or alt. dimming lights points to alt. getting 14.3- 14.4 volts reading on UG, that matter?
Old Mar 4, 2024 | 08:03 AM
mollusc's Avatar
Your alternator isn't charging.
Old Mar 4, 2024 | 09:30 AM
JohnZo's Avatar
Re: Alternator. If lights dim, voltage could be low. If voltage is low, spark is weak. If spark is weak, truck struggles. Any OBD codes? Low voltage can set lots of codes, leads to limp mode.
Old Mar 4, 2024 | 01:48 PM
H20nSnow's Avatar
About electricity...you will not have the same voltage everywhere. If you lights are dimming, you have lower voltage at the bulb. If at the same time your lights are dimming, you see solid ~14.3V at your UG, then your OBD connector is getting good voltage. That means that your alternator is likely fine. You get different voltages at run time when you have bad cables or connections. A bad ground strap connection can cause this sort of behavior. Check both ends of all ground cables/straps and ensure that they are clean and tight.
Old Mar 5, 2024 | 10:24 AM
Richard Gallant's Avatar
Have your battery tested as well.
Rev'dup1
Sep 29, 2019 08:46 PM
RawFaith
Sep 15, 2016 02:03 PM
jneil
Feb 28, 2010 08:39 PM
yarddawg
Dec 10, 2007 05:19 PM
Larry
Jun 7, 2007 07:48 PM
