Code Help
Old May 31, 2012 | 04:17 AM
Most live data scanners will show volts from O2s out to three decimal places, some cheap meters don't go that far. So the answer is either, but both are handy to own. And this may be a good excuse to buy an Ultra Gauge.
Old May 31, 2012 | 07:50 AM
Might also inspect the wire harness for damage as well as the connection for oil or dirt.
Have you been going thru a lot of oil or coolant on bank 1 that could be contaminating that 02?
Old May 31, 2012 | 08:52 AM
Kalel's Avatar
It did have oil leaking on that side. Would cleaning out work? I could try that while I get a hold of a good scanner.
Old May 31, 2012 | 10:02 AM
You won't know till you clean it but the leaking v/c gasket will allow oil to get on the connection and mess with your 02.
Old May 31, 2012 | 12:06 PM
Kalel's Avatar
Oil leak has been fixed, I have a buddy with a Hawkeye scanner and he is coming over to help out.
Old Jun 1, 2012 | 09:29 AM
Did you clean the 02 connections with electric contact cleaner?
Old Jun 1, 2012 | 12:47 PM
Kalel's Avatar
Not yet, my father in law, who is 86, fell and broke his ankle. I have been dealing with that, as a stay at home dad, but my buddy will be here today and I can get to work on it.
Old Jun 1, 2012 | 07:06 PM
Kalel's Avatar
The readings are odd. It starts up and has voltage, then it reads 0 volts and % and open. Bank 2 shows proper numbers and closed. Now when you rev the engine the numbers go back up, back to idle the numbers go to 0. He is coming back next week to do a point to point test to check the connector and wiring.
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
