codes
Old Mar 3, 2010 | 11:30 AM
chad420's Avatar
Default codes
Just got my truck back from the shop had a power steering pump installed, mass air flow sensor (will tillery), and he bleed my brake system.
Now the new codes that Im getting are as follows:
p0171
p0174
po734
p0733
c1234
c1155
u1262
b1676
c1233
c1440
c2770
Any help on these would be appreicated??????
Old Mar 3, 2010 | 11:37 AM
How long after you had the work done did it take for the codes to come back?
The 171, 174, 733 and 734 are because of a bad MAF. The rest are body and some other codes not related to the engine.
Old Mar 3, 2010 | 01:31 PM
hilltoppersx's Avatar
agree with mike, MAF codes showing the o2 sensors, then you have other things going on....
evap code, 2770 isnt that an acceleration sensor?
1676 = battery pack voltage out of range,
1262 = Communication Bus Fault,
1233 = Front Left wheel speed Input Signal Missing,
1155 = Speed Wheel Sensor LF Input Circuit Failure,
1234 = Speed Wheel Right Front Input Signal Missing,
Old Mar 3, 2010 | 02:33 PM
tornado_735's Avatar
Do you happen to have a K&N Air filter in there? Those will kill a Rover MAF in a hot damn minute.
Old Mar 3, 2010 | 03:35 PM
+1 tornado,... make sure you are using a paper filter, not an oiled up K&N that will kill your MAF
Old Mar 4, 2010 | 09:56 AM
chad420's Avatar
I don't think he cleared my codes after he put my new MAF sensor in. Should he have cleared them after he installed the MAF sensor??? DONT USE K&N FILTERS....I use AMSOIL PAPER FILTERS.
Old Mar 4, 2010 | 10:49 AM
yeah he should have cleared them after the MAF install... i think that is only one of your many problems, buy yourself a reader. they are cheap $30-$50 or you can get a nicer one with more features but with all the code reading it will save you some money instead of going to get diagnostics done every time you make a fix.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
