Codes From ABS Amigo
scan your truck again.
i have to get mine tomorrow and pull it to make sure. i know it stores every scan it has completed in the .txt file, but i think they are numbered seperatly which i don't see on your txt.
am i correct in saying you only plugged the amigo in once?
previous faults is a previous scan. If this is your Amigo and this is the third time you scanned your truck than yes listen to Mike. If you bought this Amigo used OR are borrowing it from someone, AND this is the first time you scanned your truck then that fault is not yours. I'm trying to make sure that the repair you are going to undertake is actually for your truck. The way the Amigo works is it saves every scan that is had done. Your amigo shows it has scanned three times and found a fault only on the second scan. Hope this helps you understand how it works.
1.--Current Faults---->
Active Faults:
None
Logged Faults:
None
<-END Faults
..--Previous Faults--->
Active Faults:
022:ECU Gnd or Reference Gnd bad
Logged Faults:
None
<-END Faults
Active Faults:
Comms Error
Logged Faults:
Comms Error
<-END Faults
Looks the same. Also, I am using this on a Mac with Office software. WOuld this be making the outcome look any different, as i know the interactions say us eon windows based PC
Will do, they have only come on once so now it's just a waiting game. Nifty device I have if I don't ever need it!
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
