Codes + M & S lights blinking
Old Nov 20, 2010 | 01:18 PM
Arizona man's Avatar
Default Codes + M & S lights blinking
My 2002 DII is idling at 2k rpm at startup then dying down to about 600 rpm once it warms up. Im getting codes for the Cam position sensor, TPS, MAF sensor, O2 sensors, two evap codes, and the M & S dash lights are blinking. I replaced the TPS last week, cleared the codes, and they all came right back. When I give it gas it bogs out and the rpms instantly drop. The coolant reservoir is also boiling after about 10 minutes of idling.
Does the 4.0L V8 have a temp sending unit or just a coolant temp sensor... where should I start from here?
Old Nov 20, 2010 | 01:52 PM
yloDiscoII's Avatar
Sometimes the M + S lights can be indicating a low battery output (anything below ~13A will cause the lights to go off, putting your tranny in limp mode). I would start by getting your battery tested (and replaced if needed) and seeing where that leaves you.
Old Nov 20, 2010 | 02:13 PM
Rovin4life's Avatar
hey is fuse 2 engine compartment blown. its a 15 amp fuse.
m and s blinking could be the xyz switch out of synch. but that would be a 705 code.
Old Nov 20, 2010 | 02:28 PM
I'm going to have to power probe the fuses to see if any are blown. The battery is brand new so that's definitely not the issue.
Old Nov 21, 2010 | 11:15 AM
vishrb's Avatar
I had a brand new battery and still woudl get these flashing lights. I inspected the battery connecters and found a light coating inside one. I sanded it smoooth and got rid of the m&s lights. You probably made sure those were clean but just in case I thoguht I would mention it.
MarkJN110
Nov 15, 2020 07:10 AM
rogerrover
May 29, 2012 07:35 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
rick.scott
Jul 4, 2009 12:01 PM
