Codes P0733 and P1844
Old Dec 15, 2010 | 08:21 AM
msilverman239's Avatar
6th Gear
Default Codes P0733 and P1844
I recently posted about disco II that won't accelerate and I've discovered codes P0733 and P1844. I wonder if these codes put the car in "limp home mode" and won't allow car to accelerate. Does this effect the advance of timing? And what are the remedies? The car seems to shift ok.
Old Dec 15, 2010 | 08:59 AM
First, do you know what "Limp Mode" means and how it will drive if in limp mode.
I wouldn't worry about the 1884, it will go away when the 733, tranny out of ratio in 3rd. gear, is fixed.
Normally that code won't come up unless the MAF is failing and then you would also have some other codes indicating the engine is running to lean or rich.
You might try unplugging the MAF and see if it drives any differently.
Let us know what you find.
Old Dec 15, 2010 | 08:02 PM
6th Gear
Thanks for the reply, I'll try unplugging MAF in AM. Will let U know.
Old Dec 16, 2010 | 12:51 PM
6th Gear
Default unplugged MAF
I unplugged the MAF and took it for test. The vehicle still won't accelerate. Seems to drive the same with or without MAF. What is that telling me? I'm also still having problems that I can't get a scanner to communicate with the vehicle's computer. Any thoughts?
NWROVERS
Mar 10, 2015 03:17 PM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
Lupdiesel
Nov 23, 2008 06:14 PM
