codes and seafoam
Old Feb 28, 2008 | 06:14 AM
zerochills's Avatar
Default codes and seafoam
So, I had been idling rough for a while and been making repairs accordingly. I change air filter regularly (yes I did run a K&N for about 16000 miles until reading post against use and terminated use about 8000 miles ago, hopefuly MAF is not shot but certainly a possibility). I flush the engine periodicaly. Recently replaced Iridium plugs with Bosch +4 and installed a set of Magnecore wires attempting to erradicate a cyl.#5 misfire. Shortly after I performed a Seafoam treatment on the induction system. Now 1500 miles later scanned the codes and to my surprize had 12 faults. Some were dublicates indicateing misfires on cyl. #5, #6, & #7, also had P1300-random misfire, had P1590-rough road fault, P0171 and 2 codes which indicated I need to replace my O2 Sensor (which I had already known and am currently scheduling the time to replace).
Question: would the Seafoam treatment temporarily cause multiple fault and misfires???
Any other suggestion direction on approach would be helpful.
138000 mi.
Thanks
Old Feb 28, 2008 | 07:37 AM
Default RE: codes and seafoam
Go clear the codes and recheck. Yes I have seen a couple of times where Seafoam will throw a misfire, especially on a heavily carboned engine.
So, go clear them, see what pops up then get back to us.
NWROVERS
Mar 10, 2015 03:17 PM
buick56
May 15, 2013 06:11 PM
mcwilly21
Jun 1, 2011 06:40 PM
Torancis_LR
Jul 5, 2009 07:56 PM
Phototone
Mar 31, 2008 01:06 PM
