Coil Packs
Old Oct 23, 2017 | 07:20 PM
EasyDoesIt's Avatar
I picked up a Standard Motor Products UF-545 Ignition Coil, 8mm magnecor wires, and ngk g power plugs for my 2004 and its been great for the past 1000 miles.
The coil pack ran about $45 shipped.
After the tune up I got 17mpg on a 700mile round trip to Phoenix.
Good luck.
Old Oct 24, 2017 | 07:07 AM
CollieRover's Avatar
Thanks for all the responses guys. I did some research, and I believe the plugs have 30k plus on them. I decided to do Bosch Iridium instead of NGK so I do not have to gap them.
Old Oct 24, 2017 | 09:36 AM
Alex_M's Avatar
I'd highly recommend any brand plug other than Bosch. They make notoriously bad spark plugs and I wouldn't use them even if someone gave me them for free. Gapping is super simple and a gap tool is only like 98¢. Other brands make pregapped plugs too if you're just totally against gapping them yourself, but its really super easy.
Old Oct 24, 2017 | 10:11 AM
OverRover's Avatar
So true! I wouldn't run a Bosch spark plug in a lawnmower. It's NGK for me.
As for "pregapped plugs", you still need to CHECK the GAP anyway so just get a good gap tool. Very simple process.
Old Oct 24, 2017 | 10:18 AM
Best4x4's Avatar
x2 DO NOT use the Bosch platinum plugs with the flush mounted center conductor!!!!!!! Or the silly x2 or x4 Bosch plugs. You will have misfires very shortly & you’ll be thinking coils & wires when it’s just a crappy fouled Bosch plug.
NGK Platinum or Iridium are excellent plugs & I’ve had fantastic results in LR V8’s. (Fairly certain NGK plugs are OEM in the LR3). Heck even Autolite Iridium or Double Platinum work good. Whatever you use just do yourself a favor and avoid Bosch plugs like the plague!
Also as said above you should always check the gap no matter what.
Old Oct 24, 2017 | 11:03 AM
KingKoopa's Avatar
Any opinions on the current run of champion platinums? My local rover specialty shop strongly disapproved of them. This is of course after I had already installed them.
Old Oct 24, 2017 | 11:50 AM
Best4x4's Avatar
Last Champion Platinum’s I used did not perform well. I went with Autolite Iridium as they were the only ones in stock & I liked them much better vs the Champions.
Old Oct 24, 2017 | 12:06 PM
Dang! Looks like I am returning the Bosch plugs!
Old Oct 24, 2017 | 12:29 PM
KingKoopa's Avatar
Mad mileage? Bad throttle response? Misfire?
Funnily enough there isn't a lot of solid data on champions within the last 5 years or so.
Old Oct 24, 2017 | 12:42 PM
Best4x4's Avatar
Bad mileage? Bad throttle response? Misfire?
Random misfires
