Coil Packs
Did you guys have to drain the coolant?
Now, is it possible for one person to lift that baby out without risking damage to something? Or is it better with two people?
"If" you still have your throttle body heater plate installed then you'd have to add a step by removing the 4 8mm bolts holding it to the intake and then just sit the throttle body on the valve cover. Besides that zero coolant lines are messed with.
New gasket if I do?
My tb is more or less frozen to the upper. I tried to pull it off, quickly decided it wasn't worth it when a couple whacks with a dead blow didn't achieve anything. Have had similar experiences with other vehicles. Just putting that out there, that path may be more work than just unbolting and setting aside.
When I initially changed my plugs/wires I did it with the plenum on. Took 3+ hours and a lot of cursing/busted knuckles. Once I started it and went for a test run, I had 3 misfires. Turns out I didn't fully seat 3 of the plug wires on the coil pack.
My advice, remove the plenum and be done in the same amount of time with less cursing and fewer busted knuckles.
I replaced the plenum gasket but from the looks, it probably wasn't necessary.
Steve
Steve
