Cold air under the dash while driving
Old Jan 18, 2018 | 09:27 PM
Sandman614's Avatar
Originally Posted by Friday Night Disco
The air, noise, and moister is coming in from the wheel well as there is nothing from blocking it. It then goes and finds a way past your door seals into the cabin.
I don't have the part number but, here would be my recommendation...
Take the wheel off and check the wheel liner for fitment/ tears. You may need to order a new one.
Easy cheap approach...get some expanding foam or caulking and fill the gap from the door side.
I appreciate it. I'll look into it more and keep post my solution.
Old Jan 20, 2018 | 09:04 AM
Frank4's Avatar
How bout you install the glove box part you are waiting on an forget about it. I this is an out there thread if I’ve ever seen one.
Old Jan 20, 2018 | 09:29 PM
Sandman614's Avatar
Because if it's a hole of some sort which outside air is coming in then water might be able to come in. I don't want my rover to be ragged.
Old Jan 21, 2018 | 10:26 AM
shanechevelle's Avatar
Take a hair dryer and blow air around the firewall and door areas. Do it with the truck off and see what you find.
Maybe the area under the windshield?
TRIARII
Aug 7, 2014 11:34 PM
rezzrover
May 7, 2013 06:02 PM
dirklemond
Jul 29, 2012 01:06 PM
RoverLady
Apr 26, 2012 08:56 PM
