Common Problems
Head gaskets, leaky valve covers, worn out u-joints in front driveshaft and worn out roto-flex coupler in rear driveshaft, sagging headliner, window regulators, plugged radiator, power steering pump and hoses, ABS/TC/HDC Lights on (3 Amigos), sunroof leaks/not functioning and leaky o-rings on the heater core. Also, listen for any ticks at idle when engine is cold and then when hot. A tick that is only present when hot might indicate a slipped liner.
Disco Alan
07-10-2006 08:18 PM
