Composite vs Steel Valley Pan Gasket
Old Jul 3, 2022 | 06:26 AM
MSGGrunt's Avatar
Default Composite vs Steel Valley Pan Gasket
Is one better than the other? I am gathering everything needed for a head gasket replacement and would like to use whichever is better. I read somewhere that an aftermarket steel one is offered that could be better than the composite but can't seem to find it again.
If composite is there a difference in quality between OEM Rover, VR, Fel Pro, or any other brand?
I am not always a fan of "kits" as they may not include all of the best brand gaskets unless someone has a good recommendation? And without a doubt I will be using ARP studs in place of the OEM torque to yield bolts.
Old Jul 3, 2022 | 07:10 AM
Alex_M's Avatar
I've had good luck with the cheap head gasket kits in the past, though if you're looing for name brand then Fel-Pro is always a good product and widely available.
Old Jul 4, 2022 | 06:53 AM
MSGGrunt's Avatar
Atlantic British seems to sell a good kit and I think the valley pan gasket is metal. A quick call should clarify. And they sell a kit that includes the ARP studs, so if the head gaskets are VR or equivalent that may be the way to go.
Not sure why I am hung up on a metal valley pan gasket over a composite one, but I think I read somewhere that the metal was better. Just like my other post asking about metal layered head gaskets. I don't mind spending the extra money if it is a better and longer lasting product, especially with regard to head gaskets.
zeroone
Oct 25, 2015 02:04 AM
FlyingZebra34
Jul 4, 2013 04:43 PM
Barat11
Apr 10, 2013 12:57 AM
03discoman
Mar 15, 2010 09:32 AM
chad420
Oct 24, 2009 02:51 PM
