Compression test results and plug photo.
Old Oct 23, 2017 | 04:51 PM
Lisa Bunch's Avatar
Default Compression test results and plug photo.
Finally did the compression test on my 00 D2. Cold engine, removed fuse #10 (fuel pump) and fuse #14 under steering column for coils. Checked left bank first, forgot to open throttle playe, though I don't think it mattered. All plugs removed.
Old Oct 24, 2017 | 07:06 AM
Red5's Avatar
Based on the compression numbers, you need head gaskets. You're def leaking between 3 and 5 I think. If that's what you were asking.
Old Oct 24, 2017 | 07:43 AM
Lisa Bunch's Avatar
Yep, the problem common to this engine finally hit me. Looking back, I think it has been failing for a while. It explains why my heater gurgles, why I can't seem to burp the air out of the cooling system, why my water pump failed catastrophically one day, why the o-rings on my overflow cap fail all the time, why my radiator started leaking, and why it occasionally overheated for no reason. When I blew out the spark plugs before removing them for the compression test there was a mist of water, and I realized it was coming from between the head and block on the left bank. I knew right then what the compression test would find, but I wanted hard numbers ( and bruised forearms! ). What amazes me is how well it ran after I filled the fuel tank and drove it 60 miles before other problems surfaced. I think my current issue is a bad cks. Still, I will wait for the elm327 to arrive, drive with it a day, then mothball the Landy until I rebuild it.
DiscoBuckeye
Nov 28, 2017 04:44 AM
dougn
Sep 16, 2014 10:15 PM
bradman951
Apr 22, 2013 01:07 PM
twaszak
Nov 30, 2010 08:06 PM
btbaus
Jan 20, 2010 04:38 PM
