Compressor to Condenser Hose replacement questions?
Ok Gentlemen.
I used the search and it turned nothing up and the Rave manual doesn't really touch on it.
After using the sniffer I found that the Hose from the Compressor to the Condenser is bad. I am REALLY not wanting to have to pull the radiator and I am hoping there is a trick to getting it out without having to do so. I noticed the black plastic cover in the Drivers fendrwell and was curious if I removed it (riveted on side closest to bumper) it would give me access to what I need to slide it out and run the replacement. ANY help is appreciated.
I already have the new drier, replacement hose, PAG46 oil, o rings just need some direction before I crack this open. Prefer not to take a hammer when all I need is a scalpel.
Thanks Guys
Thanks Guys
Remove the black plastic cover. It gives you access to the line. I believe it is secured to the chassis in that area. This is the area where mine rusted out around that secure connection. A bigger pain is removing the grill to access the front for the drier and the connection to the condenser. Not a big hands friendly area.
landrover mike
Build Threads
Jun 16, 2018 09:40 AM
