Compressor to Condenser Hose replacement questions?
Old Jul 13, 2024 | 12:00 PM
Johnyakimo1855's Avatar
Default Compressor to Condenser Hose replacement questions?
Ok Gentlemen.
I used the search and it turned nothing up and the Rave manual doesn't really touch on it.
After using the sniffer I found that the Hose from the Compressor to the Condenser is bad. I am REALLY not wanting to have to pull the radiator and I am hoping there is a trick to getting it out without having to do so. I noticed the black plastic cover in the Drivers fendrwell and was curious if I removed it (riveted on side closest to bumper) it would give me access to what I need to slide it out and run the replacement. ANY help is appreciated.
I already have the new drier, replacement hose, PAG46 oil, o rings just need some direction before I crack this open. Prefer not to take a hammer when all I need is a scalpel.
Thanks Guys
Old Jul 13, 2024 | 06:09 PM
Windycity_rover's Avatar
Remove the black plastic cover. It gives you access to the line. I believe it is secured to the chassis in that area. This is the area where mine rusted out around that secure connection. A bigger pain is removing the grill to access the front for the drier and the connection to the condenser. Not a big hands friendly area.
Old Jul 13, 2024 | 10:02 PM
Thanks for the reply!
Yes I see that on the grill. Fortunately for me I havent mounted the ARB yet so I can access it fairly easy.
1997Defender90
Defender
May 12, 2024 10:27 PM
JMF20
Dec 27, 2023 04:17 PM
VPALLARI
Mar 15, 2022 05:33 PM
landrover mike
Build Threads
Jun 16, 2018 09:40 AM
russburcham
Nov 29, 2017 02:54 PM
