Considering purchase 2004 DII
Old Dec 17, 2014 | 01:34 AM
Susvman's Avatar
Default Made the plunge
I ended up purchasing the 04 DII, after giving it another once over the vehicle seemed to be in good shape and the previous owners appeared to ensure the vehicle was serviced by the dealer at all of the recommended service intervals. The lady I bought the vehicle from was given the DII for repayment of a debt and she only put a couple hunderd miles on it since she owned it. The oil was changed last year with only 200 miles on it since the change and was super clean. So clean it was hard to tell the level on the stick. With 204K on the odometer I was surprised at how clean the oil appeared.
Since the purchase, I replaced all of the brake pads and front rotors. The front brake needed replaced but the back were still really good. Changed out the front, center, and rear diff lubes and had the brake system and tranny fluids flushed. The LH seat switch was fried and replaced it with one from ebay..$23 easy fix. Replaced a burnt out dash bulb and drained 1/2" of water out of the LH head light assembly. Not sure how that got in there. Waiting for a RH window regulator, the current one is trashed. Everything else appears to be working. Have had a P0420 code pop up twice now if I get on throttle hard on bank one (RH side I believe) I suspect the cats may need replaced. It does have a slight ticking once it's warmed up. Sounds like a common problem. Will have to investigate in the future where it's comming from. Attached is a pic of the seat switch. It was definitely chard!
Cheers
Susvman
Nov 28, 2014 01:32 PM
pauldavidanthony
Mar 20, 2012 09:10 AM
hiljak
Jun 20, 2007 06:01 PM
mrkbbd
Jul 18, 2006 08:10 AM
gatorfan91
Feb 18, 2005 12:51 AM
