conversion of D2 to camper/expedition vehicle?
Old Apr 3, 2016 | 02:58 PM
pilsner's Avatar
Originally Posted by Colorado David
I have at times temporarily removed my back seats and slept in the back. I am 6' and barely fit with the front seats moved all the way forward. I had to move my stuff from inside to the roof rack to make room and it was a bit of a pain. I would like to build something similar so that I have secure storage and and place to sleep without having to move so much stuff around. I need to be able to drive to a location where I will photograph at sunrise and sleep there. Right now I have a child seat for my grandson in the back seat most of the time. When he has outgrown the carseat, I will do something.
How hard is it to remove the upright only portion of the rear (NOT 3rd row) portion of the seats? -or- is it easier to just fully remove rear seats all together and make a platform to square up with cargo area foot print? TX.
-Pilsner.
Old Apr 6, 2016 | 11:32 AM
Alex_M's Avatar
Just saw you never got a response. Removing the whole seat is very simple. I believe its only 4 bolts per seat. Maybe 6 on the longer one, but I don't think so. You'll need a large torx, can't remember what size off the top of my head.
Old Apr 6, 2016 | 12:35 PM
Colorado David's Avatar
Sorry I missed this question. I removed the seat, not the seat backs. The seat backs fold flat. The seats are spring-loaded, so while removing them isn't hard, putting them back in is a bit of a challenge. Not insurmountable, but simply challenging. In the future, I'd like to avoid it so I will eventually make a platform that will fit over the folded seats and provide storage below.
Old Apr 7, 2016 | 07:56 AM
LR03NJ's Avatar
David, Got a Q. When you removed your seats, did you remove including the springs? I would like to remove mine but I'm not sure if the springs will unwind and not be able to reload it back. I just want to replace the torn seats (larger side) but the other replacement I have does not have springs. So, my replacement requires the springs to be moved to the other seat. Is that doable?
Old Apr 8, 2016 | 06:07 AM
The springs are part of the hinges and are under tension has you undo the bolts. I'm not sure I have the answer to your question. I've only done this a couple of times and it's been two or three years ago now. With a child seat in the backseat it's a little hard for me to do it very often.
Old Apr 21, 2016 | 04:42 PM
pilsner's Avatar
Can the rear seats be removed individually? As in removing just one and the center section while leaving one in back for a kid's seat or a second adult (my dog says he called DIBS on shotgun long ago...)?
Thanks.
-Brian and Tomah
Old Apr 21, 2016 | 05:41 PM
Alex_M's Avatar
You can. I had mine like that for some time.
Thanks.
-Brian and Tomah
PoppitCampersLtd.
Sep 16, 2015 02:43 PM
PoppitCampersLtd.
Defender
Sep 16, 2015 09:03 AM
Spensive
Mar 19, 2010 06:36 AM
apcollin
Nov 6, 2008 09:04 PM
