coolant?
Old Oct 24, 2008 | 10:41 AM
tbriska's Avatar
Default coolant?
I noticed when I went to top off my coolant the coolant in the res. was pink, the dexcool I bought was orange. Is it ok to add the orange stuff to the pink??? Thanks
Old Oct 24, 2008 | 10:56 AM
Default RE: coolant?
Yes. But you really need to change your coolant, when it changes color it is breaking down and all that will be left is acid, and it will eat your gaskets.
When was the last time it was changed, do you know?
Old Oct 24, 2008 | 11:12 AM
tbriska's Avatar
I am not sure,It just came off warranty 5 mo. ago.
Old Oct 24, 2008 | 11:27 AM
Urban Panzer's Avatar
a few Interestings read here
http://www.search-autoparts.com/sear...27/article.pdf
http://www.aa1car.com/library/2005/us90554.htm
http://www.aa1car.com/library/2004/us120426.htm
Old Oct 24, 2008 | 01:07 PM
How many miles on your truck and when was the coolant last changed?
Old Oct 24, 2008 | 01:29 PM
tbriska-Have your cooling system flushed. Because you dont know when it was or even if it was done before you bought the truck.
Confusing ain't it?
Here is what I know...Land Rover uses DexCool from the factory in DII's, they recommend changing the coolant every 45,000 miles or 36 months, whichever is sooner.
DII's develop head gasket leaks around 80,000 miles. Most DII's have never had their coolant changed.
Here is what I learned from when I sold coolant...DexCool contains acid and becomes extremly corrosive IF not properly maintained. i.e. it becomes contaiminated with either air, other coolant or other foreign matter, scale for example.
Mechanics HATE DexCool, even GM Goodrich mechanics. Everyone that I talked to ran their own DIY shop in their garage at home and they all refused to use DexCool outside of the GM dealership. They had to us it at work but would'nt "use that crap in my own car."
So in my humble opinion when topping off use what is in there all ready, if you are going to do a flush and fill use whatever you want.
Bottom line, change it every two years regardless of miles or type that you use.
Personnaly I use Peak Global Lifetime Coolant 50/50 premix and drain and fill every two years.
Old Oct 24, 2008 | 02:25 PM
tbriska's Avatar
Thanks spike, will do.
ZMonet
Jun 24, 2016 04:00 PM
CANAMDiscovery
Apr 24, 2012 07:19 AM
G Reeves
Feb 21, 2012 02:39 PM
skeester
Dec 30, 2011 05:42 AM
