Coolant Drips on Oil Pan/Oil Pan Gasket Leak
Old Jun 6, 2020 | 05:45 AM
Magnolia18's Avatar
Default Coolant Drips on Oil Pan/Oil Pan Gasket Leak
Hello to all; needing some advise on what is going on with my Rover.
I took my Rover in to have it looked over and was advised that my Rover was
leaking from the oil pressure switch; had it done so I thought I was good to go.
two days after driving I notice that I was still leaking oil but not as bad. So
I am guessing what the fixed helped some but no all. Also when the car is running
I see the coolant Reservoir with cap on looking like water boiling in a pot. Rover
never runs not drove over 230 miles with no over heating. Here are some pic
please advise. Thanks
This is on the front part of oil pan.
Old Jun 6, 2020 | 07:19 AM
The Deputy's Avatar
If that coolant on the valve cover is drivers side, inspect throttle body heater/hoses. If passengers side, inspect heater hoses or metal tubes for leakage. Coolant is running down from above to land on oil pan.
Some coolant flow is normally visible in the reservior. Especially if you have a leak, which we know you do, and air is in the system.
Old Jun 23, 2024 | 06:31 PM
etchevers's Avatar
i have somthing similar did you resolve the problem ? how? i imagine because the post is 4 years old
s10lowrider1994
Aug 15, 2018 10:24 AM
erick846
Dec 1, 2015 11:19 AM
Rover_Hokie
Sep 27, 2012 04:42 PM
03DiscoTwo
Jun 20, 2012 08:29 AM
kean
Feb 24, 2009 03:41 AM
