Coolant error
Old Aug 23, 2007 | 09:32 AM
Default RE: Coolant error
ORIGINAL: bigugly82
since I'm going to have to drain and refill, which coolant should I use?
If you don't want to replace your head gaskets even more frequently at $2400 a time at the dealer then use what Rover says to use, DexCool. Now that is not to say you can't add some of the coolant suppliments on the market, like Royal Purple, but NO yellow or green coolant PERIOD.
Old Aug 23, 2007 | 10:09 AM
okdiscoguy's Avatar
ORIGINAL: Landzu
From what I understand the yellow coolant is replacing
the Dex-cool.
From what I have read, they used the yellow in a few models before fully changing to Dexcool. It has been around a lot longer.
Old Aug 23, 2007 | 10:34 AM
May have been around alot longer, and personally I don't care if people don't want to run what is called for cause all they are doing is risking head gasket failure and I know how much shops like to see engines come in after using some other coolant and now it needs head gaskets.
Like the old saying goes, you can lead a dog to water but you can't make him drink.
Old Aug 23, 2007 | 01:34 PM
okdiscoguy's Avatar
I am a good dog Mike. I switched to Dexcool after you recommended it. Iam very happy with it. If you know of any more watering holes I need to visit, let me know.....
Old Aug 23, 2007 | 02:11 PM
bigugly82's Avatar
Is there any benefit to adding water wetter, etc with new DexCool?
Old Aug 23, 2007 | 02:55 PM
okdiscoguy's Avatar
Sure, just make sure whatever you run is compatible with Dexcool. I threw some Purple Ice in with mine...
Old Aug 23, 2007 | 03:27 PM
okdiscoguy's Avatar
Unless your coolant is discolored, just flush with water.
Old Aug 23, 2007 | 04:30 PM
Landzu's Avatar
Here it is Disco I's is green antifreeze`.
Disco II's is Dex cool, I call Land Rover of Dallas.
So DiscoMike right, so do it.[sm=exactly.gif]
Old Aug 23, 2007 | 04:32 PM
98roverguy's Avatar
ORIGINAL: Landzu
Thanks. I was wondering why the heck I couldn't find anything on Dexcool in my owners manual...
mjgallivan
Jan 1, 2015 10:41 AM
Ajibola
Mar 27, 2012 07:34 AM
pixel
May 13, 2011 07:24 PM
igenov
Audio/Visual Electronics
Feb 4, 2006 06:54 PM
