Coolant hose leaking under pressure
Old Feb 24, 2018 | 11:09 AM
Jadden14's Avatar
Exclamation Coolant hose leaking under pressure
Just installed new top radiator hoses as the one hose connecting to the radiator was leaking... now the bottom hose attaching to the thermostat is leaking. I'm not sure if I tightened it enough or if it's that coolant is building up too much pressure. I can attempt to move it down some more but I really need to figure out what's causing all this coolant loss as it's been slow leaking for a while now...
Attached Thumbnails Coolant hose leaking under pressure-15194921266601661443298.jpg
Old Feb 24, 2018 | 12:25 PM
Best4x4's Avatar
Replace the clamp with a new style clamp and toss the OEM style for starters. Then if it still leaks replace the lower hose and call it a day.
Old Feb 25, 2018 | 05:19 AM
The Deputy's Avatar
Most likely, the new hose has thinner material and the constant tension clamp is not causing enough pressure...or it is just gething weak. Anyhow. Agree, replace with screw type clamp and see what that does for you. Just don't go to crazy tightening, since you are working with a plastic housing on stat.
Brian.
Old Feb 25, 2018 | 07:47 AM
LR03NJ's Avatar
Yes you can replace it wirh the screw type clamp and go from there. Good that yoi are not overheating. Is the thermostat original? A lot in the forums use the grey 180 degrees but there are also that color with soft spring from AB.
Old Feb 25, 2018 | 09:51 AM
Best4x4's Avatar
I’ve had better luck with the black Britpart 180F honestly vs the OEM Grey 180F thermostat lately. Just DO NOT buy a Motorad branded thermostat whatever you do!
Old Feb 25, 2018 | 05:45 PM
Jadden14's Avatar
I used a screw clamp and coolant stopped leaking from the hose. All I need is time now to truly figure out if my coolant loss woes are gone, hopefully it's no longer, it used to be refuel gas and fill up coolant XD
Old Feb 26, 2018 | 03:38 PM
OffroadFrance's Avatar
Check the top hose when the truck is well warmed up, if it feels solid with no give in it you probably have other problems like an overheat or being pressurised by a leaking HG. Of course a dodgy thermostat would give similar results so don't tear the heads off until you eliminate all the easier options.
Old Mar 3, 2018 | 09:23 AM
Jadden14's Avatar
Well I checked my coolant and it's still leaking. I looked into the possibility of the HG, as it's right around that mileage(108k). No steam goo on oil cap, oil is normal in color, and no loss if power, not really giving any symptoms. I guess I'll have to pressure test the system, maybe check the plugs. I'm currently running an auto zone thermostat, no motors, a duralast, and I'm open to the possibility to that being the problem.
Old Mar 3, 2018 | 11:19 AM
Best4x4's Avatar
Unless Autozone has gone to another Vendor most of their thermostats are indeed made by Motorad. Get a Britpart 33.00 black 180F thermostat at least or the 66.00 OEM LR Grey one. Where is the leak coming from??
Waterpumps can seep (two long bolts go straight into the cooling jacket), Throttle body heater plate, brittle plastic lines to radiator and Throttle body heater plate, and of coarse the radiator itself.
xisled
Jan 16, 2018 11:59 PM
Joelhimself
Apr 19, 2017 10:03 PM
TopCat
Aug 19, 2014 01:05 PM
roving patrol
Oct 13, 2012 09:36 AM
nashville_disco
Aug 7, 2008 04:12 PM
