Coolant Leak.
Old May 23, 2023 | 10:35 PM
cybercop's Avatar
Default Coolant Leak.
Been trying to figure out a coolant leak. Finally replaced the Reservoir and seemed to help from a sitting still standpoint, but when you run the truck, I get a dribble from the location in the photos below. I do not think the lines that the drops are coming from are coolant lines. Where do you guys think the leak is coming from?
Old May 24, 2023 | 12:02 AM
JohnZo's Avatar
How about the water pump?
Old May 24, 2023 | 12:28 AM
cybercop's Avatar
I hope not, but I will check it out
Old May 24, 2023 | 02:20 AM
Discorama's Avatar
Check the bolts of the water pump from above. The longer bolts which go into the block can leak since some of the threaded holes connect to the coolant passage. Just tightening the bolt in question might fix it. If not, you can try to reseal the bolt(s) in question.
Old May 24, 2023 | 07:47 AM
Extinct's Avatar
And of course check the weep hole
Old May 24, 2023 | 08:41 AM
cybercop's Avatar
Weep hole?
Old May 24, 2023 | 10:01 AM
Harvlr's Avatar
At the bottom of most (maybe all) water pumps is a small hole that will start weeping coolant out when the water pump seal is beginning to fail.
Old May 24, 2023 | 05:28 PM
cybercop's Avatar
If I use a Coolant system pressure check/tester kit, will it expose these issues around the water pump, or does the truck actually have to be running and warmed up
Old May 24, 2023 | 07:09 PM
Extinct's Avatar
Pressure tester is an excellent idea.
Old May 25, 2023 | 07:34 AM
The_OGCJR's Avatar
i believe you would need the thermostat open…. So warmed up?
