Coolant Leak from Overflow
Old Jul 9, 2024 | 09:34 AM
Moffatbwr's Avatar
3rd Gear
Default Coolant Leak from Overflow
2002 Landrover Disco 2
Im getting coolant pouring out of the connection to the overflow. Thoughts? Or if anyone has a thread on this already that would be great!
Old Jul 9, 2024 | 10:08 AM
Harvlr's Avatar
Is it over filled?
Old Jul 9, 2024 | 10:12 AM
Moffatbwr's Avatar
3rd Gear
It looks like the coolant actually needs a top up. However I don’t think it would be wise to top it up with this leak. It’s a very heavy leak. Car is running fine. Not overheating. It’s like the coolant from the engine isn’t even going into the reservoir, it’s just pouring out of the clamp. I tightened the clamp, no luck. I just noticed a slight crack in the coolant reservoir end fitting (where the tube attaches). I’ll replace the reservoir and see if it fixed the issue.
Old Jul 9, 2024 | 10:31 AM
Moffatbwr's Avatar
3rd Gear
Looks to be the issue! I have a replacement reservoir which has the same crack. Ordering a new one hope it resolves it 👍🏼
Old Jul 9, 2024 | 01:00 PM
Harvlr's Avatar
That should for sure do it
Old Jul 9, 2024 | 08:48 PM
mln01's Avatar
Always start with the most simple, least expensive remedy.
I'd start with replacing the reservoir cap.
Garrett Larrow
Oct 13, 2020 09:57 AM
fleacz
Sep 18, 2018 01:21 PM
Joshman
Apr 16, 2013 11:48 AM
jkid
Apr 28, 2008 06:59 PM
jerome
May 21, 2007 04:26 PM
