Dowty washers?
Old Jul 4, 2024 | 12:52 AM
evil_goat's Avatar
Question Dowty washers?
Are dowty washers required on the bolts that are outside the block and connect to the crankshaft bearing caps? On Atlantic British it is $50 for all of them. Is there somewhere better I can get them? Are there alternatives to using them? It seems the ones on the bolts have disintegrated or might even be missing so I cant re-use those.
Are there any other small items I might have forgot need replacing in an engine rebuild?
Old Jul 4, 2024 | 10:42 AM
H Hill's Avatar
Bite the bullet and buy the new ones. They are for one time use. Worth the investment.
Old Jul 4, 2024 | 03:04 PM
JohnZo's Avatar
Agree with above. They are used to seal oil leaks and can be installed on oily surfaces. Probably could use silicon sealant instead if sealing surfaces are clean and dry, but silicon will be messy next go round.
Old Jul 4, 2024 | 07:19 PM
Externet's Avatar
Old Jul 5, 2024 | 11:05 AM
Extinct's Avatar
Unless they are damaged you can re-use. Liberal use of silicone also recommended.
Old Jul 5, 2024 | 12:25 PM
evil_goat's Avatar
The washers have pretty much disintegrated. Are you saying that liberal use of silicone is recommended in addition to the washers, or can be used as an alternative?
Old Jul 5, 2024 | 02:48 PM
Extinct's Avatar
In addition. You can try as an alternative and if they leak you can put them on later.
Old Jul 10, 2024 | 12:44 PM
WaltNYC's Avatar
https://www.mcmaster.com/products/~/...hers~/?s=dowty
pricey little devils
evil_goat
Jun 25, 2024 11:38 PM
matt3502
May 5, 2021 05:35 PM
Fastercat
Jul 18, 2020 04:39 PM
Stephen Perez
Mar 4, 2020 04:26 AM
Carlos Man
Oct 31, 2019 08:45 AM
