coolant leak question?
I am leaking coolant from one of two hard lines. I can see it dripping off the lines on the passenger side right behind the motor, about where the tranny bolts up. It appears to go underneath the firewall & right above the transmission. I think these maybe the transmission cooler in/out lines? whats the easiest way to go about changing one or both of these?
It has set in my driveway for about 10 months due to heater core going out so I bypassed the heater core for a test drive & so it wouldn't have to be towed to a garage, that's when I found the leak in those hard lines. It was also really blowing some white smoke so it may be done for. I only let it run for about 5 min but are there any other reasons that a it would be crop dusting my neighborhood?
I have already looked at that diagram(have a rave pdf file) & I don't see the lines I am referring to on there.there are two hard lines on the passenger side of the bell housing that appear to be the ones leaking. they look like they run under the firewall. I will try to get a pic
This pic was taken on the passenger side just behind the exhaust manifold. the lines I am referring to are the ones that are horizontal in the picture. You can see they run under the firewall. Not for sure coolant is coming from inside the lines but it sure looks that way. It could be running out of the head gasket on the backside of the motor & running down these lines.![](https://landroverforums.com/forum/<a href="<a href=http://s290.photobucket.com/user/widowmaker223/media/IMG_7424_zps6394ac9e.jpg.html" target=_blank>http://s290.photobucket.com/user/widowmaker223/media/IMG_7424_zps6394ac9e.jpg.html"</a> target="_blank"><img src="<a href=http://i290.photobucket.com/albums/ll244/widowmaker223/IMG_7424_zps6394ac9e.jpg" target=_blank>http://i290.photobucket.com/albums/ll244/widowmaker223/IMG_7424_zps6394ac9e.jpg"</a> border="0" alt=" photo IMG_7424_zps6394ac9e.jpg"/></a>)
![](http://<a href="<a href=http://s290.photobucket.com/user/widowmaker223/media/IMG_1319_zps36326d46.jpg.html" target=_blank>http://s290.photobucket.com/user/widowmaker223/media/IMG_1319_zps36326d46.jpg.html"</a> target="_blank"><img src="<a href=http://i290.photobucket.com/albums/ll244/widowmaker223/IMG_1319_zps36326d46.jpg" target=_blank>http://i290.photobucket.com/albums/ll244/widowmaker223/IMG_1319_zps36326d46.jpg"</a> border="0" alt=" photo IMG_1319_zps36326d46.jpg"/></a>)
ZMonet
06-24-2016 04:00 PM
MyRoversNameIsCarl
08-10-2014 09:22 PM
aguison
11-18-2012 05:15 PM
lipadj46
07-08-2009 07:41 PM
