Coolant Squeeze Lock Clamps - Fail?
Old Jan 29, 2019 | 02:40 PM
Motorhead1's Avatar
Originally Posted by abran
I also use the same spot on the hose, but my reason has always ben esthetics.
I think there is a clear reason why Land Rover uses these constant tension clamps on all of their vehicles.
When launching our coolant tank we sourced constant tension clamps as we feel they are better. But some of the feedback has been that DIY guys don't like them as you need a specific tool to use them easily.
I've never owned or used the special tool, mine are channel locks/pliers for my desired need, BUT I think a purpose built tool would be cool. Years ago I learned about "same spot on the hose" due to having leaks after a cooling system job, first thing I did was move the hose clamp to the original position and the leak stopped... So just a habit of mine now, and like you Abran, for esthetics.
Old Jan 29, 2019 | 03:04 PM
ahab's Avatar
I agree!
Old Jan 29, 2019 | 03:09 PM
abran's Avatar
^ That might well be the reason. But I hope that the savings is negligible when it comes to using the clamps.
Also, Assembly might be cheaper with the constant tension clamps.
Old Jan 30, 2019 | 06:28 AM
Sandman614's Avatar
I just started using them and only once.
Could this be a ninja turtles reference
Old Jan 30, 2019 | 09:41 PM
Ben Matheson's Avatar
I must have that clear insert. Where did you get it
Old Jan 30, 2019 | 10:21 PM
Saturnine's Avatar
He posted a thread on it — just do a search!
Old Jan 31, 2019 | 08:32 AM
Gladly if I knew what it was called or some search key words that would find it
Old Jan 31, 2019 | 10:55 AM
DiscoNickBK's Avatar
WHOA that's awesome
Old Jan 31, 2019 | 11:12 AM
Think I'll do the worm clamp on the thermostat area once it warms up a hair. Might add a drop of locktite to the threads as well. Can't hurt... Anyone in NYC have a super strong pair of clippers I can borrow to get these tension clamps off?
Old Feb 6, 2019 | 08:12 AM
Sandman614's Avatar
I just ordered some Breeze liner hose clamps for the silicone radiator hoses that i installed. i guess it could have been the squeeze clamps leaking but... Silicone is cool and should last longer. Now I know the squeeze clamps are leaking..
Amazon Amazon
