Coolant Squeeze Lock Clamps - Fail?
Old Feb 6, 2019 | 09:42 AM
  #21
ahab's Avatar
Still can't narrow down the coolant smell although replacing the squeeze clamp on the thermo housing did correct that leak. Yesterday I pushed the system up to 20 PSI and waited. I climbed under the truck to begin an oil change change when I noticed some dripping. Followed it up and found this on a relatively new hose and tube. Constant tension clamps 0, stainless worm drive 2. It may be that age is the problem here, it obviously isn't a design issue since they've been in use for a long time.
Old Feb 6, 2019 | 04:59 PM
  #22
Extinct's Avatar
I would recommend you replace that entire plastic tube with automatic transmission hose - they get brittle with age and crack, leak. So does the radiator end tank, but that is a little more $.
Old Feb 6, 2019 | 06:07 PM
  #23
ahab's Avatar
Agreed, but that part is new on this truck.
humroot
Sep 28, 2019 11:07 PM
Jadden14
Mar 3, 2018 11:19 AM
cappedup
Feb 18, 2015 09:33 AM
buick215
Nov 13, 2010 08:52 AM
jaredm
Aug 22, 2010 02:48 AM
