cooling fan removal
Old May 20, 2015 | 09:49 AM
RANDY04D2's Avatar
Default cooling fan removal
Got 4 hrs into trying to get this cooling fan off. Holding the clutch with tool and trying to loosin nut does nothing. The clutch spins independently of the nut/shaft. The belt dosent hold the waterpump shaft/nut enough to loosen fan. Pulled belt and tried a strap wrench on pully, still slips. Any ideas that worked from experience?
Old May 20, 2015 | 10:22 AM
5kcstq's Avatar
Short answer is: Hold the pulley not the clutch. I replied in your other thread as well.
Either use an air chisel on the edge of the nut, hit a 32mm wrench on the end with a steel hammer while the belt is on, or use the proper pulley holder.
Old May 20, 2015 | 10:37 AM
RANDY04D2's Avatar
Right. Did the hammer on the wrench. Belt still slipped on pulley. Applied more tension on tensioner whilst hammering still slipped.
Old May 20, 2015 | 10:38 AM
RANDY04D2's Avatar
Will go the hold the pulley route with a thicker strap wrench whilst hammering wrench. Just had this fan off 2 yrs ago....Thanks....
Old May 20, 2015 | 11:34 AM
dusty1's Avatar
I use the sheath off of an axe head.....it is like a thick leather wedge. I stuff it between the hb pulley and belt, in a way so that the more I loosen the fan nut, the tighter the belt gets and effectively holds shaft in place while I turn the wrench.......has worked for me 100% of the time
Old May 20, 2015 | 11:44 AM
drowssap's Avatar
yup leave the belt on tight, stuff rags between the pulley and the belt, as you tighten the rags will jam the pulley
Old May 20, 2015 | 01:29 PM
DustyLBottoms's Avatar
Every time this question comes up people share their cheap methods; however, buying the official special tools for this was the best $200 I ever spent. No more busted knuckles, no more cursing, it literally take me 15 seconds to remove the fan clutch now.
Old May 20, 2015 | 01:32 PM
abran's Avatar
Old May 20, 2015 | 01:34 PM
Originally Posted by abran
That brought me to house fans?
The rover part number for the holder tool is: LRT-12-215
The part number for the double wrench is: LRT-12-214
You can buy both here: https://landrover.service-solutions....ory/1/1/Engine
Old May 20, 2015 | 01:39 PM
abran's Avatar
I fixed the link. Sorry. Its a craftsman. Check it out.
