Cooling issues after SAI fix
Old Jan 19, 2021 | 02:54 PM
boostedt0y's Avatar
Originally Posted by whowa004
check motor mounts as that often leads to interference with the fan and the shroud..
Thanks! I'll look into that as well!
Old Jan 19, 2021 | 02:55 PM
Dave03S's Avatar
Also, the front drivers side screw holding the upper shroud plastic in place is the shortest of the screws used in shroud, because if you use the wrong longer screw it will puncture the plastic radiator tank right below it.
Make sure you didn't put a longer screw in that position or you will be needing a new radiator.
Other than that, Great Work!!
I would still check the level in the bleed hole again tomorrow for peace of mind.
Old Jan 19, 2021 | 02:56 PM
ahab's Avatar
Originally Posted by Chris59
All Peak coolant? This Peak Coolant has OAT inside - the Euro Vehicle Pink bottle.
That's an excellent point. No, not all Peak Coolant. There are many Peak types, more than I was aware of anyway, so it's extra important to make sure what's been added is compatible.
https://peakauto.com/peak-antifreezes-coolants/
And of course Peak confuses the issue by calling their OAT coolant OET...
Great news, and nice job finding the leak. A fan clutch can overheat and get damaged being held like that for extended periods so make sure it doesn't spin easily once you clear the obstructions.
Hephaestus
Feb 28, 2017 07:58 PM
JimmyChooToo
Jun 28, 2016 04:13 PM
Beaulim
Jan 27, 2016 11:30 PM
matt3502
Jan 17, 2015 04:38 PM
bballjames
Oct 24, 2012 05:53 PM
