Trouble passing state emissions
Old Jun 28, 2016 | 06:38 AM
JimmyChooToo's Avatar
Default Trouble passing state emissions
Truck is a 2003 DII LEV. I replaced the SAI solenoid, so my p1415 code is gone for good. I'm still getting the p1412 on cold starts. I tried Rapid Pass, the remote sensing drive through emission test in my state and the truck failed. No loophole there.
Not sure what my next best strategy is. Dump a bottle of "Guaranteed to pass" from Walmart and try Rapid Pass again or clean the SAI valve and try to pass the traditional route. My registration expires in a day or two. I have the slipped sleeve ping (seems manageable now), and the truck drives great with lots of pull otherwise. Coolant temps are around 201F in the summer and 194 on the highway.
Old Jun 28, 2016 | 08:24 AM
d.a.r.y.l's Avatar
Jimmy,read this thread it discusses the P-1412 code. Might be helpful. D*
https://landroverforums.com/forum/di...ictures-23113/
Old Jun 28, 2016 | 09:20 AM
number9's Avatar
Not much to go by from your post. Have you gone through fault finding/tests in manual? Starts on pdf page 277 in my download copy. Maybe something simple like linked thread.
P1412 Secondary Air Injection System – Malfunction Bank 1 LH (Insufficient SAI flow
during passive test)
EMISSION CONTROL - V8
17-2-44 DESCRIPTION AND OPERATION
SAI System Fault Finding and Check
Malfunctions
The SAI system diagnostics monitor the whole SAI system for correct operation. Malfunction of any one of the SAI
system components can cause fault codes to be stored in the ECM diagnostic memory.
Old Jun 28, 2016 | 01:26 PM
squirt's Avatar
I just looked up that rapidpass system, and it's interesting. What if you turned the engine off and coasted through? What if you're dripping oil onto the exhaust and that's contaminating your results? Seems pretty hokey, and I doubt that your SAI issue has anything to do with it, considering SAI is only active when you hear the pump running.
Old Jun 28, 2016 | 04:13 PM
Its camera's are measuring acceleration as you accelerate through (they put them on the on ramps). If you try to coast through, you have zero chance of passing. But then neither does my 1960s Buick engine.
bretbassi
Apr 24, 2016 06:23 PM
CUpgt
Oct 1, 2013 11:52 AM
NickDII
Jan 23, 2012 12:00 PM
Osiris
Sep 19, 2011 09:17 PM
CronicJoeBlunt
Oct 2, 2006 05:24 PM
