SAI operating temps
Old Oct 23, 2012 | 10:33 AM
bballjames's Avatar
Default SAI operating temps
Hey everyone,
Quick question. I was reading the RAVE and just wanted to confirm, the SAI pump will only activate when coolant temp is below 131 F and the ambient air outside must be at least 46 F? It's getting quite chilly here and just noticed today and yesterday that on a cold start my SAI has not turned on. I am assuming this is because it is below the operating temp of the SAI per the RAVE?
Thanks for your input.
Old Oct 23, 2012 | 05:51 PM
That woud be correct.
Old Oct 23, 2012 | 05:56 PM
lr2001silver's Avatar
Banned
You got it!
Old Oct 23, 2012 | 06:25 PM
ashtray's Avatar
What does the SAI look like? I'd like to know if I've got one...
Old Oct 23, 2012 | 09:07 PM
coors's Avatar
Do you hear a vacuum cleaner like sound at cold start ups? If yes, you have SAI.
Do you see two tubes going into either end of your heads? Look just above the spark plugs and exhaust manifolds. if yes, then you have SAI.
If you're still not sure, Google it.
Old Oct 23, 2012 | 09:44 PM
ashtray's Avatar
I dont have SAI : ( bad thing?
Old Oct 23, 2012 | 09:55 PM
Banned
No not a bad thing its a emissions thing and as I've read in others signatures "one less thing to have to fix"
Old Oct 24, 2012 | 09:50 AM
jfall's Avatar
You don't have SAI??
You want it??
Sort of like-
Do you want a root canal?
SAI will come on - in the morning in a temperature band
when it is 55 to about 80 or so.
And most of the time.
SAI may come on after the first 10 minutes too - when you are in traffic just for a second.
Today - my SAI did not come on in the morning at all and it may have been 45 degrees out.
I dislike the SAI.
More reasons to LOVE a Discovery I.
Who needs more things to break and to make CEL come on?
Try to change headgaskets with SAI?
And you must remove the "gas pipes" and they break...
Old Oct 24, 2012 | 05:53 PM
ashtray's Avatar
Well I guess not have SAI is fine with me. I also read somewhere that if you ever want to put headers on these motors it is better to not have SAI.
gatorm
Aug 11, 2017 04:04 AM
gpelite
Jul 27, 2013 09:28 PM
Dan7
May 21, 2013 09:00 AM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
