Cooling question
Old Nov 10, 2013 | 08:57 PM
dusty1's Avatar
Default Cooling question
Parked, My idle temp is 193 f. If I raise the rpms to 1200 it drops quickly to 184f. Is this normal or not? I am concerned that I have an issue because I had a sticky tstat last week now I am OCDing .
Input please. Thank you.
Old Nov 10, 2013 | 08:58 PM
dusty1's Avatar
180 t stat.
Old Nov 10, 2013 | 09:47 PM
dr. mordo's Avatar
It's normal. When you raise the RPMs the water pump circulates more water and the fan draws more air thru the radiator.
Old Nov 10, 2013 | 09:55 PM
dusty1's Avatar
thank you, sir
Old Nov 11, 2013 | 03:44 AM
Is this a 180F Land Rover stat or Motobad aftermarket? Most LR stat users have not reported this operation, but I do agree with the Dr on the cause. And we have pix posted of 65 mph with 182F...
Might also check on fan clutch, fins of radiator blocked, etc.
Old Nov 11, 2013 | 07:39 AM
dusty1's Avatar
thanks, everything is new in the cooling system, save the heater core (it has been flushed x6 and is good). it is lr stat
dansgt
Oct 11, 2010 11:15 AM
cwood
Oct 3, 2010 10:40 AM
Pwn777
Jun 29, 2010 06:50 PM
Rover Chris
Jun 25, 2010 07:18 AM
cardinal77
Jun 4, 2009 02:41 PM
