Cooling system help
Old May 3, 2018 | 06:14 PM
redwhitekat's Avatar
Default Cooling system help
ok landy helpers don't know what else to do
recently purchased my 03 disco it had the oem stat it was running 205-225
so I got the lucky 8 stat black britpart low temp flushed system and added green coolant as it still had the red stuff
bled the system properly lifted reservoir etc nice stream coming out of the bleed screw
I can't get my temps down under 200
city im running 205 220
hwy 200-210
could a faulty coolant cap be my issue ???
Dont know what else to do
Old May 3, 2018 | 06:34 PM
JUKE179r's Avatar
How many times did you flush the coolant system? I normally do 4-5 flushes.
What did you flush the coolant system with? Straight water?
If it is an old cap, go and replace it. They are about $15.
Old May 3, 2018 | 06:43 PM
I flushed it about 2 times with garden hose and system wasn't really dirty as this 03 had regular maintenance
Old May 3, 2018 | 06:46 PM
Friday Night Disco's Avatar
I agree get a new cap
I also think you should work on isolating the issue
1. ensure T-stat is working
2. ensure fan clutch is working
3. ensure heater core is not clogged
Check the last couple pages of this thread for what person did
https://landroverforums.com/forum/bu...e4/#post646250
Old May 3, 2018 | 07:03 PM
No Doubt's Avatar
hwy 200-210
Lower temps when driving highway speeds typically suggests a bad fan clutch. Lower radiator shroud is on? Upper radiator shroud is on? Fan blades intact, not chewed up?
External radiator fins aren't clogged (I once had a newspaper stuck across a radiator from road debris!)?
Getting a steady stream of coolant out of your bleed screw probably means that your water pump is fine (it's moving that stream of water).
Next you can test your coolant to insure that no exhaust smoke is entering.
I use a product called "Cool Down" in a bottle that dropped my coolant temps about 6 degrees F. Maybe it will help you. Heck, use 2.
Also, insure that your thermostat is fully opening. 50-50 coolant to water, not 100% coolant, etc.
See if turning your cockpit heat to High will lower your coolant temps, too.
Old May 3, 2018 | 07:15 PM
No Doubt's Avatar
Also, check that you have a full 6.9 quarts of new oil because a low oil level and old oil will cause your motor to run a little hotter.
Old May 3, 2018 | 07:39 PM
Fan clutch is running fine lots of heat from cab heater I even put water weter
i clean the rad with water
fresh 50/50 mix
would a bad coolant cap cause overheating ??
Old May 3, 2018 | 07:45 PM
Best4x4's Avatar
When you say the fan clutch is operating fine, are you outside the D2, revving it up, and watching the fan clutch to see if it engages/disengages? It's always going to be spinning, the key is if it's actually engaging/disengaging. You can grab a Dorman 620-112 Fan Blade and HD/Severe Fan Clutch for less than 75.00 normally. 03-04 one piece unit is nearly 300-350.00 for a new one and it's a total waste of time to replace it with the OEM unit when you can grab a two piece unit for under 100.00.
You've either got a bubble in the system, or a part of it isn't functioning properly. Radiator could be clogged as well (especially if it's the OEM unit) and I don't mean internally. It could be clogged up with mud, dirt, bugs, leaves causing poor air flow thru the radiator = isn't going to be able to cool down the coolant.
Old May 3, 2018 | 07:55 PM
Going to try again tomorrow
fan clutch does engage etc
rad is clean on outside
will try new cap and get out my infrared gun
Old May 3, 2018 | 09:40 PM
Ok so I ran the truck up to temp reached 210 all hoses on my rad are hot really hot bottom hose is cold cold
could I have a bad stat ?? I'm starting to think my rad is clogged ??
It's a brand new lucky 8 stat
