cooling system hose installation - need some guidance
Old Jul 30, 2012 | 05:55 AM
  #21
bballjames - 15 psi is a good test value, cap vents at about 18. If staying at 204F, then something is not quite right. Stock stat starts to open at 180F, and is fully open at 204F. If at 204 always, you are running so warm that thermostat is not controlling the temperature. Would be more normal to see warm up, fall back, and stay at somewhere less than 204, moving up to 204 or a little higher when run hard, then returned to idle (freeway and then into the drive thru lane at burger joint). Perhaps radiator is somewhat restricted.
Christopher121 - see cooling system download in my signature. Read each section. Helps if you tell us what kind of Land Rover you are working with, and if not a Rover, we'll still try.
Old Jul 30, 2012 | 10:37 AM
  #22
bballjames's Avatar
Thanks for the info Buzz. I think she might run a tad warm... usually on the highway I'm at about 195 average. While in stop and go traffic usually about 200-208 depending on ambient air and if A/C is going. While idling for a couple minutes though will usually sit right at 199-200. Haven't been concerned with those temps yet, but I might throw in the freelander thermo to lower those temps a bit.
Old Jul 30, 2012 | 10:43 AM
  #23
Those are good numbers, pretty much the same as mine in 95 degree weather with the a/c on. A soft spring will bring them down by around 10 degrees, which is what I am going to do money permitting.
evoblade
Feb 25, 2015 11:48 AM
TRIARII
Feb 21, 2013 10:33 PM
Griff Drew
Dec 30, 2011 07:26 PM
matt3502
Sep 3, 2010 10:10 AM
disco 2 range parlay
Aug 6, 2010 12:03 PM
