Could a coolant leak into the engine ruin the engine completely?
Old May 2, 2012 | 12:08 PM
  #21
willrok13's Avatar
How much are you in to it for? Upside down? If the body and interior are in good shape, you could expect somewhere around $2,000-$2,500, but not much more than that. If its in poor condition probably less. You could part it out, but you're looking at time and space required to disassemble everything, and you may not sell enough to get your money out I it. Plus, I hate seeing discos parted out that could be repaired. Such a waste of a great automobile. That being said, what are you looking to get out of it? I may be able to help you out. PM me if you want to talk.
Old May 3, 2012 | 07:45 AM
  #22
rreinholt's Avatar
Quick note, had the same problem a few years back, the stealership said the leak was the head gaskets. Replaced them and found no other issues but still had coolant in the cylinders. They suggested Bars Leak since they then thought it was micro pores in the block since my wife ran the truck dry of coolant one day. 2 years later, truck is still running. It's a cheap try to fix the truck.
Old May 3, 2012 | 08:56 AM
  #23
willrok13's Avatar
True. Since the block is known to be bad it may be worth a shot. But take note that the system may become clogged--mainly the radiator and heater core. Risky, but may buy some time. Would I do it to my truck? Not in a million years.
Old May 3, 2012 | 09:40 PM
  #24
This stuff works GREAT!!
K-Seal™ Permanent Coolant Leak Radiator Repair - 8 Oz (K-SEAL Same Fit As Part # ST5501D) - Land Rover fluids & oils from Atlantic British
I've used it.
FOXMILLER
Off Topic
13
Mar 4, 2014 05:09 AM
Draayer
Jun 7, 2011 08:06 PM
KBW
Nov 29, 2010 10:46 AM
catchthebig1
Aug 16, 2010 03:10 AM
mattyh007
Sep 18, 2009 10:37 AM
