Could I ruin my trans by towing it?
Old Jun 7, 2011 | 02:47 PM
Draayer's Avatar
Default Could I ruin my trans by towing it?
I'm getting a 2000 disco II in exchange for a debt, the head gasket is blown but the deal is, I buy the parts and the seller has a mechanic to fix it. Where it is presently parked is about 5 miles from the mechanic, can it be towed saftly there or I've heard that it can overheat a transmission if you go too fast? Could it be driven or will it warp heads? What would you experts recommend?
Thanks,
Old Jun 7, 2011 | 03:00 PM
hilltoppersx's Avatar
Are you sure that the truck is in running condition? After the head gasket has blown serious damage can be done if the truck overheats. I suggest you read up on how to do a headgasket job and pick up as many parts as you can. If I were you I would flatbed the truck. I wouldn’t recommend trying to drive it with a blown head gasket.
Old Jun 7, 2011 | 03:16 PM
Draayer's Avatar
Default Could it be towed
I'm really not sure how it will go after the head gasket is fixed, the reason I mentioned I'm getting the rover in exchange for a debt is because I'm guessing that taking the rover is the only way I will get anything so I will be into the rover the cost of the head gasket and head bolts.
So will it hurt the rover to tow it? I have also heard that if it is towed slow (below 30) that I would be ok, is that true?
Thanks,
Old Jun 7, 2011 | 03:49 PM
jeffh's Avatar
drop the drive shafts... or put the transfer case into neutral and travel slowly..best bet would be to flatbed it...
Old Jun 7, 2011 | 07:56 PM
As long as the transfer cased is in neutral you can tow it just fine, this will remove the transmission from the equation.
And yes, if you tow a automatic transmission car with the drive wheels on the ground and the engine NOT running you will overheat the transmission because without the engine running there is no fluid being pumped through the transmission.
Typically you can tow this way at speeds upto 50mph for upto 1 hour with a 1 hour break to allow the trans to cool off.
However, if the engine is running and the trans is in neutral you can tow it as far/long as you want with no harm to the trans.
Old Jun 7, 2011 | 07:58 PM
I need to add that with a full time 4x4 driveline like on the Disco it MUST be towed with all four wheels either on or off the ground.
NO CAR DOLLY!!!*
*unless you remove the rear propshaft.
Old Jun 7, 2011 | 08:06 PM
coors's Avatar
LR DII Lifting and Towing.pdf
Thanks,
Got this from RAVE for ya.
FOXMILLER
Off Topic
13
Mar 4, 2014 05:09 AM
sadain
May 3, 2012 09:40 PM
catchthebig1
Aug 16, 2010 03:10 AM
mattyh007
Sep 18, 2009 10:37 AM
dinandan
Jun 22, 2006 07:22 PM
