Couldn't make it to Scarr? Maybe you can make it to Scabb
Old Jun 3, 2014 | 10:19 AM
  #71
ls1morethanyou's Avatar
Texas Beach Cams
we might be ok, but surfside is trashed.
south padre
surfside
Old Jun 3, 2014 | 11:00 AM
  #72
yeah, its in houston- a buddy from the jeep club lives there and thats what he posted, from the last update on pins they said the weeds are on the move away from pins.
I cant wait to hit the beach! the smittybuilt jerry can holders are being mounted today after some modifying.
Old Jun 4, 2014 | 08:18 AM
  #73
ralphobell's Avatar
Try taking a short drive to Cabela's and see if they have them. If not you might also check an Academy.
Old Jun 4, 2014 | 09:01 AM
  #74
ralphobell's Avatar
Yeah I was talking about the Cabela's in Buda.
Once you remove the console and knock out the rivets, you can get to everything from the top. Hardest part is getting to the 2 bolts closest to the passenger side.
Unplug all the connectors that sit on top of the selector. Tie them out of the way. I then removed the shift cable that will no longer be used. Then tie up all the other cables to the rivet holes with zip ties. This will give you more room to work. Feel free to call me if you have any questions.
Old Jun 4, 2014 | 09:04 AM
  #75
I didn't see any so I went with the pre built ones, I'll run up there later tonight after work.
On the cdl install you will only cut a square piece for the del lever to go side to side and up down. You do everything from the top, drill out rivets and go to town.
A level surface helps because you are messing with the shifter and a good wheel chuck comes in handy.
Old Jun 4, 2014 | 09:10 AM
  #76
ralphobell's Avatar
Your going to need a stubby wrench to get to those last bolts or I was able to get to them with one of these:
Combo Go-Thru Socket Set - SAE & Metric 21 Pc
Old Jun 4, 2014 | 09:54 AM
  #77
i used one of these with a short socket
1/4" Heavy Duty Composite Ratchet
Old Jun 4, 2014 | 11:02 PM
  #78
did anyone say shark fishing? Local guy here makes them, i have one for me and one for Jared.
i have tomorrow off and as soon as i get back from Austin (friend has an emergency) ill be flipping the tire carrier and loading up to head out at 10:30.
Old Jun 5, 2014 | 05:40 PM
  #79
dusty1's Avatar
nah. it'll be fine.
i usually put the rack on top of the truck, though.
Old Jun 5, 2014 | 07:36 PM
  #80
I about spit my drink out, thanks dusty.
Packing has been kicked into high gear and we will be ready in a few to head out. Triple checking everything twice.
