A couple of odd questions.
Old Nov 24, 2011 | 07:56 PM
Merlin390's Avatar
Default A couple of odd questions.
1. Does anyone know the diameter and pitch of the transmission fill plug?
2. The inside diameter of the transmission cooler lines?
3. Has anyone sucessfully put disco II headlights from the 03-04 on to a 2001?
Thank you.
Old Nov 24, 2011 | 10:09 PM
1-I dont know.
2-I dont know.
3-Yes, but why? They leak and fill up with rain/carwash water.
Old Nov 24, 2011 | 10:22 PM
buick215's Avatar
I agree with Spike. The 03-04 headlights tend to get water in them and condensate, leading to corroded sockets. They will also turn yellow and get scratched since they are plastic and not glass like the older ones. Bottom line is that they look nicer and make the truck look newer but aren't as practical and in the long run will look worse.
Old Nov 25, 2011 | 07:25 AM
Merlin390's Avatar
Good to know in the headlights so scratch that idea. Any info on the other is appreciated
Old Nov 25, 2011 | 10:48 AM
OpenApe's Avatar
1. M16 x 1.50, it's also 13mm long with a 8mm allen head
2. Sorry, can't help you with this one
3. x2 on the headlights. Mine have condensation in them, are scratched up, and have UV damage.
Old Nov 25, 2011 | 01:15 PM
jafir's Avatar
Most of the water problems are from people not being careful when changing bulbs. When I got my 03, one of them was half full of water. I took it off, drained the water out and re-seated the caps that cover the bulbs. There hasn't been water in it since. They are plastic, so the outside will get scratched and cloudy over time. I wonder if someone makes a clear plastic sticker to put over them....
Old Nov 25, 2011 | 04:06 PM
bosshogt's Avatar
When changing the bulbs in 03-04 headlight be sure to properly align the rear caps with O rings, fully turned till locked. There are tiny triangles that must point to each other, that how you know they are down tight. I have had them off and on So man time when I fitted HIDs I'm really good at it. My rover is now 7 years old and no yellowing or moisture inside. I did put a bag of those silica beads in there that come in new items in the mail. They suck up moisture. I dont think the clear will yellow with time because its poly carbonate, not just clear ABS plastic. I use the 4 fin headlight guards to protect mine and have been lucky so far. I think Rover makes them and so does Travel from England.
IMHO, the 03 headlight really make the car look cool. But if I had a 00-02, I dont know if I would spend the $400 to retro fit. Its a lot of money for a purely cosmetic mod.
Old Nov 25, 2011 | 08:32 PM
You need the headlight lens restore stuff that is a big seller now days since everyone uses plastic instead of glass headlight lens.
Old Nov 25, 2011 | 11:20 PM
jafir's Avatar
Yeah, I just meant to protect them before they get all cloudy on the outside.
tornado_735
Mar 20, 2009 09:24 PM
thairs
Apr 13, 2006 05:50 PM
AndrewBone
Aug 4, 2005 01:17 AM
UNCRover
May 10, 2005 02:45 PM
Bene
Freelander
May 10, 2005 01:41 AM
